Go to Post This is definitely the best FRC parody of an FRC parody I have seen. - Jared Russell [more]
Unread 27-03-2011, 18:17
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Re: pic: Lamp_Switch
This is the switch we use. There can be no way of not passing this switch during inspection. The switch actually has "limit switch" written right onto it. It works perfectly. A little pricey but gets the job done. This switch, once engaged, requires you manually reset it. Hence the name "manual reset safety limit switch". Here is the McMaster part number 7336K51
http://images2.mcmaster.com/Contents...ng?ver=1180392
