#17
Re: paper: MINIBOT acceleration solution
This has the spec motor curves built in but by playing with the parameters, you can easily make it look like the dyno model. I measured the coefficient of drag as .22 for our minibot model using a high speed camera and a drop test. The coefficient of drag is defined as Drag_force/Normal_force. This model used Tetrix kit bearings. Typically the friction force is 6 to 7 newtons for our 2.5lb minibot. We always measure it with a newton scale prior to each run. A excellent approximation to the climb time can be made by using your variable definitions. The steady state climb speed v_ss = D/B (should be the same as peak_pwr/W) System time constant tau = 1/B Dist = pole height. Then time_to_climb = Dist/v_ss + tau This falls out of the exponential solution when the time > 5 tau which is typically the case for the minibot. To include the effects of drag... simply replace W with W + Drag. Glad to see you are spending some time to document the physics for others. I have been a little lax this year on my posts. |
