Go to Post Taking some parts from an old robot isn't cheap, it's like adding a piece with more experience to the new robot. - Marcel [more]
Unread 12-04-2011, 00:15
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
Re: pic: ummm......what?
343 did knock the crap out of us a few times. they had some great driving in that last match. but i still dont believe that the chassis could flew enough to cause that.
Unread 12-04-2011, 08:27
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
I looked at the video of the last finals match and expected to see 2415 get hit near the end and then die. The breaker was still working the entire match. 2415 deployed the minibot like normal. "It's just a flesh wound."
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 12-04-2011, 14:23
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
yea, we lucked out because it seems to have broken into the on position
Unread 12-04-2011, 14:39
EricH EricH is offline
So how did you shut the robot off afterwards?
Unread 12-04-2011, 15:09
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
I'm guessing they pulled the battery.
Unread 12-04-2011, 15:29
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Smile Re: pic: ummm......what?
I'm going to take a wild guess that it probably won't pass inspection in St Louis as-is.
Unread 12-04-2011, 16:02
Unplugging the battery when the circuit is on carries a risk of sparks, guys. I would not suggest trying that--ANYWHERE. That's why I asked.
Unread 12-04-2011, 16:03
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Just blame it on us. We looked at it funny in the semifinals.
Unread 12-04-2011, 16:16
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Travis is a jinks! You should have seen what he did to us at SMR!
Unread 12-04-2011, 16:22
O-H
Maybe the Force is with me? I do hang around with people like this, after all (the one without the ponytail...wait the Storm Trooper is a girl...I'm pretty sure she had a ponytail too...um, the one without the moustache, then).
Instead of external shock causing damage, what about something internal/structural causing the breakage?
Unread 12-04-2011, 20:41
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
What would you suggest in that situation?
- Arizona North
Unread 12-04-2011, 20:50
I would suggest a non-conductive poke stick to separate the contacts on the main breaker. Normally, that non-conductive poke stick is the red button. Separate the contacts, then yank the battery, then pull and replace the breaker. In this case, poke on that upper tab-type thing to break connection is where I'd go for first.
I've seen the sparks that can fly when there's marginal contact on a battery to some other connection (charger, bolt, other battery). They may look pretty, but you don't want to see them because they mean something's wrong.
Unread 12-04-2011, 21:06
I have never seen sparks emit from a live Anderson connector. And Ive seen them used to jump start cars. Safety doesn't mean find the hardest way to do something.
Unread 12-04-2011, 21:26
I've seen a plugged-in FRC battery spark. I forget whether it was the Anderson or the terminals, but I seem to recall that the area around the Anderson fused (read: welded) to something else before someone could get in there and separate the battery from whatever it was connected to (thankfully, not a robot in that case).
Chris, the thing about using a non-conductive poke stick on the connector is that 1) you only get one place for a spark (the breaker, which in this case is already broken) as opposed to 2 (each side of the Anderson) and 2) your hands are not right there to risk getting zapped.
I don't know about you guys, but I'm not sure I'd want my hands right next to a fully-live FRC battery's current and voltage if I had to unplug it, even with an Anderson connector between my hands and the wires. (By fully-live, I mean current is flowing actively, not current can flow if the connection is made.)
Unread 12-04-2011, 21:45
What you just described wasn't a Anderson short circuit. If two power poles fused together a wire had a short or the system drew too much current. Anderson terminals are designed for safety and useability which is why they have shielded contacts. If you really want to get technical even if there was a slight spark between the power poles it would take the path of least resistance (i.e not your hand) for the milliseconds it would have before the connectors were far enough apart. I would take my chances with this before touching a broken exposed circuit breaker.
