12-04-2011, 21:15
Re: pic: ummm......what?
Originally Posted by EricH
I would suggest a non-conductive poke stick to separate the contacts on the main breaker. Normally, that non-conductive poke stick is the red button. Separate the contacts, then yank the battery, then pull and replace the breaker. In this case, poke on that upper tab-type thing to break connection is where I'd go for first.
I've seen the sparks that can fly when there's marginal contact on a battery to some other connection (charger, bolt, other battery). They may look pretty, but you don't want to see them because they mean something's wrong.
And you don't think there's a greater chance that poking a fuse with a stick will unintentionally cause a short than unplugging an Anderson connector?
