Go to Post I miss the years when game speculation was based on an actual hint released in the form of unintelligible strings of numbers - tcallan [more]
Unread 04-04-2011, 21:52
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: pic: Tower Mishap
It happened at CT Regional as well. It landed on their own alliance pole, so no penalties incurred. As stated above, you can't remove the pole because of the wires going down through, plus the poles are locked in. The ladder supplied by FIRST isn't tall enough for someone to climb up & remove over the top. We just sliced it off.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 04-04-2011, 22:12
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
The wires can be disconnected from the base, and the poles can be removed. It just takes a few minutes to unscrew the covering at the base and get to them, disconnect the wires going up to the top of the tower, lift the pole, and then put everything back together. Easily done by two people in five minutes or less.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 04-04-2011, 22:21
MarcD79's Avatar
AKA: Marc
I'm well aware of how it comes apart. I built the CT field. It's easier to just cut it & save about 5 minutes.
Mentor & Volunteer
Unread 05-04-2011, 01:01
CallieJ's Avatar
CallieJ CallieJ is offline
The Girl With the Spirit Tattoos
FRC #1868 (Space Cookies)
Team Role: Scout
CallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to behold
Originally Posted by remulasce View Post
254's mishap with the tower was notable in that they both knocked the lights off of their own tower and rung the opponents tower... with the same tube. It was impressive.
That was Adam. He's generally pretty skilled (he was 254's human player in 2009 as well, and was deadly). I'm just surprised it only happened once- in practice they had to take that first tower down because he was breaking it so often until he improved.
Since that double red card he's been rethinking his technique, which is good for all people involved in the lab. At least now if he's practicing and he hits you accidentally you don't get bruises the next day. We were very impressed that in 254's first match at San Diego he threw a tube across the field and landed it on their claw. People from GRT were asking me if he had practiced that.....
2009,10,11 Silicon Valley Regional Finalists
2011 Silicon Valley Regional Chairman's Winners
2011 Sacramento Regional Champions
2011 Sacramento Regional Engineering Inspiration Award
2009 Silicon Valley Regional Engineering Inspiration Award
2006 Championships Judge's Award
www.spacecookies.org
Unread 05-04-2011, 08:23
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
Originally Posted by Brian Ha View Post
You know that little green light on top of the towers, you know what happens when you hit it with a tube? It falls over on it's side. The funny thing is that it still worked and our alliance got minibot points for it. (A minibot did go up it)
Twice at KC, the green light was hit by a tube and flew halfway across the field. They had to get out the dance music and a ladder to put it back, and it wasn't working afterwards at first.
Free One-Person Powerful Objective Performance Scouting PC Program from 1094:
http://www.chiefdelphi.com/forums/sh...63#post1235263
Unread 13-04-2011, 16:00
StashZabriski's Avatar
StashZabriski StashZabriski is offline
FRC #3320 (Miracles & Machines)
StashZabriski is on a distinguished road
I've put together 2 fields and helped break down 2 fields as well. As a field supervisor you don't want to waste a full round's worth of time to break down a tower and put it back together. That's IF the anchors all cooperate around the tower base and everything goes smoothly. You also take the chance that something won't be connected correctly (or at all) when putting the tower back together...which would put you even further behind on the schedule. If the field can't be dissembled and reassembled in under 2 minutes, you should just be cutting the tube off the base of the tower. Now if the tube is up top, get the ladder out as soon as it happens so you're ready to go when the match is over.
No hunter of the sky should end his days as prey. Better to die on the wing than pinned to the ground. (Eragon by Christopher Paolini)
Unread 13-04-2011, 16:10
Nick Bouressa Nick Bouressa is offline
Mechanical Lead
FRC #0166 (Chop Shop 166)
Nick Bouressa is an unknown quantity at this point
This also happened at GSR.
Our team motto...
"THINK!, There must be a harder way!"
2011 GSR Chairmans winner
