Thread Tools |
Rating:
Display Modes |
#14
Re: paper: 4 wheel independent drive & independent steering ("swerve")
Input the vehicle's wheelbase and trackwidth into cells A1 and A2. Input the forward, strafe_right, and rotate_clockwise commands into cells A4, A5, and A6. As a point of interest, note that if you enter FWD=1, STR=0.3, and RCW=0.384, you get Ackermann steering. In fact, for any values of FWD_Ackerman and Turn_Ackermann, if you input Code:
FWD=FWD_Ackermann, STR=Turn_Ackermann*sign(FWD) RCW=STR*sqrt(L^2+W^2)/L Or you can get front-wheel Ackermann steering when going forward and rear-wheel Ackermann steering when backing up if you enter: Code:
FWD=FWD_Ackermann STR=Turn_Ackermann RCW=STR*sign(FWD)*sqrt(L^2+W^2)/L Or you can get "snake" steering (both front and rear wheel steering) if you simply set STR=0 and use: Code:
FWD=FWD_snake RCW=Turn_snake*sign(FWD) Last edited by Ether : 18-04-2011 at 17:12. |
| Autonomous Independent | sparks-1784 | NI LabVIEW | 16 | 01-04-2010 09:11 |
| periodic tasks in autonomous independent | Ether | NI LabVIEW | 19 | 31-03-2010 07:15 |
| Autonomous independent-watchdog errors | ewoodring | NI LabVIEW | 2 | 20-03-2010 20:19 |
| RC independent of the OI | ajsetter | Programming | 6 | 30-03-2006 21:44 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
