Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 19-05-2011, 19:10
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
no team (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: paper: FRC148 - 2011 Robot Assembly - "Raptor"
Originally Posted by lemiant View Post
Also, what is this for? (the extrusion with a circle and two rectangles cut from it)
That looks to me like a cam chain tensioner. I have seen this a few times before. If your chains become loose, you put a special tool in the two slots, crank it down a little (because it is usually a ratchet) and wala, your chains are tightened.
