Go to Post Changing lives as a key volunteer is not a right reserved for the "elite" among us anymore. - HurdFIRST [more]
Unread 20-05-2011, 17:04
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: A little CAD practice
http://www.andymark.com/product-p/am-0286.htm
These came in the KOP I beleive last year I have no idea if they are still included. The design is from RC he is from team 1323 Madtown robotics. I know there are still some issues with them but these may work for you, they are a great design.
Good enough is the enemy of anything great!
team 1671
Unread 20-05-2011, 18:05
MattC9's Avatar
MattC9 MattC9 is offline
Ahhhh those, i did have a few of those laying around the shop for awhile but someone (that is pretty good with had tools) got a hold of it and "changed" it a bit so...i can use them. But i can always ask some of our friends to 3D print some of these.
Unread 22-05-2011, 23:30
MattC9's Avatar
Originally Posted by akoscielski3 View Post
I actually was thinking of it while sleeping... and noticed that u can use the key slots. Is everything key slot or no. Also how do you make the slot for the E-clip, is it just done on the lathe?
And is the only thing holding the shaft straight the brace on the side of the tubing + the tube?
yes, yeas and... yes!
you can easily lathe a slot for an E-clip (shaft collars and retainer clips work just as good)
The way the wheel and axle set up is laid out like this E-eclip W-wheel S-sprocket T-tubing B-bearing mount
E-W-B-T-B-S
Unread 05-06-2011, 21:21
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Do you have any tensioning plans on the outside wheels? I can't really tell, but that is important. It looks very nice, everyone always gets better after the season is over, keep it up.
I would recommend the center wheels be directly driven from the gearboxes.
Also I would suggest you may want to experiment with no tensioners and even eliminate the use of the bearing blocks on the outer wheels. It will reduce the machine time to fab the frame rails and eliminate the time used to fabricate at least 8 semi complicated parts. Simplifications like these help free up time that we have used to build a 2nd/practice robot. Good luck and keep up the CAD practice, it will really come in handy during build season.
mike d
See Ya
Unread 05-06-2011, 22:05
MattC9's Avatar
E-clip slots would be made on a lathe
All shafts are keyed
There are two braces on the tube, on on the out side and one on the inside, and yes that is the only thing supporting the shaft.
If you or anyone else wants these CAD files I would be more than willing to send them to you. (seriously don't be shy I would love some one to take a close look at this).
