Originally Posted by Hawiian Cadder
I don't know if you have Caded the bolts for the assembly, but currently it looks like they will interfere with the bolts holding your wheel together. You might want to move them farther apart, or make the bolt circle on your wheel smaller, threading outer bearing block is also an option, but it will make your setup more complex.
I am a bit confused as to what you mean by bolts holding the wheel together. The mounting holes on the performance wheels are for sprockets and gears and the such, which I am not using. There will be no bolts in those holes. But even if there were, the bearing mounts are counter-bore so the heads of the bolts are flush with the top of the bearing mounts.
My next step is to put all of the bolts in place.
