Originally Posted by Cyberphil
I am a bit confused as to what you mean by bolts holding the wheel together. The mounting holes on the performance wheels are for sprockets and gears and the such, which I am not using. There will be no bolts in those holes. But even if there were, the bearing mounts are counter-bore so the heads of the bolts are flush with the top of the bearing mounts.
My next step is to put all of the bolts in place.
that answers my question. i was wondering if you were using something like Placticons and a hub, with the performance wheels though there is no hub.
