Go to Post Go with what you know will work, and try a little less if you are feeling brave. That is my rule of thumb. - sanddrag [more]
Unread 21-06-2011, 00:43
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: pic: 4wd Geared WCD
It's also possible that Inventor is giving you a weight for solid Alu CIMs. Try unenabling any COTS or premade parts, and letting it give you a weight for only the drive base. Then add in everything else. I've found that with that method, Inventor is never more than 1/8th of a lb off, even for our robot this year. Good Luck!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
pic: My First WCD Stephi Rae Extra Discussion 24 23-05-2010 17:19
pic: WCD Chassis Idea Rion Atkinson Extra Discussion 22 21-05-2010 14:17
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: gearbox open, geared down 10:1 RMS11 Extra Discussion 4 11-08-2008 08:44
pic: Two Motor, 4WD Matt Krass Extra Discussion 9 13-09-2005 12:56
