Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Unread 24-06-2011, 22:18
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: As suggested - six robots
Originally Posted by Tom Ore View Post
They did make quite a few changes that I really like. For example when an assembly part fails, you don't have to tell it to "freeze" that part and every child part for the rest of the assembly. All parts are just flagged in red and you can fix it when you want.
That's long overdue. It was the biggest reason why the learning curve for Pro/E was so steep. (Although you eventually get used to building things in a way that mitigates the consequences of part resolution failures, when it happens, it's always annoying.)
