Go to Post You know when the school health nurse advises "always wear a condom"? She doesn't actually mean "ALWAYS". ::safety:: I think Dean and Woodie have a pretty good idea of when they need safety glasses and when they don't. Jason - dtengineering [more]
Unread 27-06-2011, 23:02
bauer5152 bauer5152 is offline
Junior Member
bauer5152 is an unknown quantity at this point
Re: pic: WCD Practice 2
Originally Posted by Hawiian Cadder View Post
If you are using .5 hex shafts I might consider turning them down to round where it goes through the tube, or making the slot 3/4 of an inch wide. As it is now, you have about 1/32 of an inch clearance between the slot and the axle when a flat is perpendicular to the slot, if your blocks are even slightly off, or if you powder coat, the axle might start rubbing on the tube.
Edit:
The link you posted is for the 3/8 hex bearing on andymark, I think that is why Chris assumed you were using 3/8 hex shafts,
I also think so.
