Re: pic: West coast drive design
We predominately use 1/16" wall, and haven't suffered any frame failures the past few seasons on any of our robots (including practice and prototypes), and a lot get really beat up. I know you're just trying to help, but it can mislead new people when you make such bold blanket statements with such confidence. Bending is the primary failure mode for frames in FRC, and the bending is directly related to the area moment of inertia. If you do some research on on how this is calculated, you'll see the shape and cross section of the tubing is what grants strength, not the thickness. |
Sorry if i have miss-lead anyone, it is not my intention. as for the failure mode. i would expect that the failure mode for 1/8 inch tube would be bending, however i would expect the failure for 1/16 tube to be bending in or getting crushed. especially if the robot takes a hard hit from the side. i think 1/16 is a LOT easier to parallelogram too. |
We've never crushed in our 1/16" wall with some brutal impacts while using bumpers. Without bumpers, the exposed corners often get smashed badly, but just the corner and it's purely a cosmetic issue. If we ran without bumpers, we'd beef it up. However, we know we're using bumpers and take advantage of it. |
if you are using flange bearings (which you have to with walls that thing) and take a hard side hit, have you ever had problems with the flange punching into the tube wall? adding a bearing block, with holes rather than slots, could help to minimize the risk of this happening. |
Can we not make claims about robot strength or material thickness based purely on guesswork please? Seriously, if you have no experience with the material, there's no shame in just not posting.
Yes, we avoid 1/16" wall on our rails for drive that have bearing blocks, etc... We're pretty sure it'd work, but for a base that's already around 30 lbs with motors, we take the few extra pounds that just two rails of 1/8" represent. |
If I don't have experience with what is being discussed in a thread I don't post anything. We used 1/16 and 1/8 tube this year on various parts of our robot, and the 1/8 turned out to be overkill on the members that did not have axles or the tower bolted on. In the members with axles or the tower bolts, we should have used more washers to prevent the tubes bending. The 1/16 was about perfect where we used it. Last edited by Hawiian Cadder : 29-06-2011 at 02:13. |
