Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 28-06-2011, 23:24
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Re: pic: West coast drive design
Originally Posted by Hawiian Cadder View Post
1/16 tubing is maybe a little thin, depending on the challenge and how heavy the robot is. The only teams i have seen using 1/16 tube also had 8 wheels, i don't know if the fact that 8 wheel drives tend to rock less violently had anything to do with it.
I am assuming that those are 4 inch wheels? If so how many stages are in your gearbox and what are the speeds.
looks pretty good. how much does it weigh?
The weight is about 28 pounds right now according to Inventor, Yes the wheel's are four inch, They have the same dimensions as the Andymark one's with a custom lightening pattern. The gearboxes have all the same internal's as a standard Andymark Toughbox, so the reduction is 12.75:1. this makes the final speed pretty slow (around 4 fps) so I'll probably half the ratio.
