Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 03-07-2011, 03:23
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Re: pic: Pigmice Northwest Drive
Originally Posted by NickE View Post
254 used 3.5" this year and 233's wheels were smaller. In recent years, small wheels have been one of the defining features of "west coast drive" robots such as this. Just look at the robots of two of the current world champions.
Why though? What is the functional advantage?
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 03-07-2011, 03:43
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Jason
-Less Weight
-Cheaper Material
-Less Machine Time
-Less Gearing, 233 may get away with only one stage of gearing?
-Better acceleration
-More efficient.
-RC
R.C.
MadTown Robotics Team 1323
Unread 03-07-2011, 18:01
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Jason
Less, and thus lighter, gearing results in the same effective ratio, also the wheels are smaller. the weight savings might be enough of a reason, but smaller wheels and the associated gearing allow the motors to operate at a different, possibly more efficient part of the performance curves.
Unread 03-07-2011, 18:36
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
That is not strictly true. While at the same rpm the smaller wheels would go at a different (slower) speed, the gear ratio could be used to compensate. While there are fewer gears necessary to get the same speed,there isn't a change in the fact that, with enough gears, you can gear for any speed
Unread 03-07-2011, 18:41
MattC9's Avatar
MattC9 MattC9 is offline
I like it, but how are you attach your SS? and why did you make a "V" in front instead of adding a front rail because the rules for the bumpers this year would not allow that. How exactly are you planning to mount the bumpers to the 1' alum. tubing on the sides? and do I spy a custom center wheel? last question I promise, hex axle or keyed axle?
But looks great keep up the good work
