Re: pic: 2011 "Nova" Swerve Drive (Front)
The steering sprockets sit on a 1" OD Aluminum tube (3/4" ID). This tube is machined from a 2" diameter Aluminum rod because at the base of the 1" tube, a 2" mounting plate attaches to the rest of the chassis (Dark grey). Hope that clears things up |
I gave up on my design because I was worried about turning the modules. The very closest I was able to move the wheels was 4" wide. The effectiveness of a swerve is limited by how fast the modules can be rotated, and with only the window motors for rotation I figured this might be difficult with such wide wheels. My next and final swerve design was a 45* module like in the 1625 teaser. In the end, this design wound up being more complicated to make then a conventional module and was only slightly smaller so I abandoned this too. Its cool seeing all the new swerve designs on CD. I wonder how many teams will use swerve next year... |
4wd 6wd tread ball drive swerve? |
Also, you didn't mean to include a differential, right? (I seem to recall a team having a design similar to this, but with differentials on all wheel pairs. Might have been 1140 around 2005.) |
Currently the gears are baseline steel.
As you probably know, selecting the Bevel Gears was by far the trickiest part of this design. If the mounting distances are too large, the wheel separation makes rotation of the module impossible. On that end, if you happen to know where I might find a hardened, spiral bevel gear set that fits near the specifications for under $120, I would greatly appreciate it.... Also, how exactly do you calculate gear strength anyways? |
And by the way, if you need more clearance for the pinion (too wide), you might consider dishing out the wheels facing the centre of the gearbox (so that the pinion and gear sit in a depression in the wheel, sort of like a typical west-coast style wheel with the spokes on one face). Typically, in FRC applications, gears fail because the teeth are overstressed. (Other failure modes are possible.) The important characteristic is therefore the bending strength of the teeth. There are a few ways of evaluating this, with varying levels of complexity and accuracy. The Lewis-Barth method is traditional and conservative, and requires relatively few parameters. AGMA has another method that takes fatigue and contact stress (another failure mode) into account, as well as a whole slew of other design factors—but you probably won't know what values to assign to them without some sort of basis for comparison. Given that bevel gears are a bit of an unusual system for an FRC application, I'd avoid relying on rules of thumb alone (so don't just take my word for it). For an introductory reference, see this. Check out the literature provided by the manufacturer. Also, there's this: a whole book about gears, with a good explanation of the Lewis method. For more about the AGMA method, I recall that any recent edition of Shigley's Mechanical Engineering Design should include a chapter (written for upper-year mechanical engineering students). You might find this a convenient resource for equations and examples. Definitely search the Chief Delphi forums for other resources. Last edited by Tristan Lall : 11-08-2011 at 03:29. Reason: More content. |
I suggest looking into worm gears, they can get you a lot more reduction in that space, and I bet it will be easier to find a set that small. with a worm gear you may be able to remove the cimplebox entirely.
According to the JVN mechanical design calculator; 7 feet per second after frictional losses. 196 LBS of pushing force with rough-top tread. |
#11
Is it possible to reduce the CIMple box further, I was hoping to get right around 10 FPS
#12
You mean reduce it less. And I would just decrease the reduction on the bevel gears.
#13
With all due respect, if you can't figure out gear ratios, you really should not be designing a swerve drive.
#14
With all due respect, I didn't post myself on this website, I posted my design. If you have a comment or criticism about that, I'd be happy to hear it. But if you only want to discourage me from experimenting and learning, I'd prefer if you kept that to yourself.
