Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 11-08-2011, 07:40
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: 2011 "Nova" Swerve Drive (Front)
I suggest looking into worm gears, they can get you a lot more reduction in that space, and I bet it will be easier to find a set that small. with a worm gear you may be able to remove the cimplebox entirely.
Unread 11-08-2011, 23:18
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I'm not generally a fan of worm gears for drivetrains (see here, at page 30 for a discussion of low efficiency, especially as the reduction increases). However, seeing as you're only replacing a CIMple Box (4.67:1), and maybe part of the 4:1 bevel gear set (since I found a 2:1 set that might work for you), your total reduction is only around 10:1. With a well-designed structure and high-quality worm gear, you can probably achieve 90% efficiency on that reduction, which is quite competitive with spur gears. You'll probably need a stiffer structure to make it happen, though (alignment is critical with worm gears).
Unread 12-08-2011, 13:40
FRC #2220
Out of curiosity, with those 2:1 Bevels, the 5:1 Cimple box, and 3" wheels, what would a good FPS estimate be?
Unread 12-08-2011, 13:47
AKA: Isaak
According to the JVN mechanical design calculator;
7 feet per second after frictional losses.
196 LBS of pushing force with rough-top tread.
Unread 12-08-2011, 13:52
FRC #2220
Is it possible to reduce the CIMple box further, I was hoping to get right around 10 FPS
Unread 12-08-2011, 14:01
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
You mean reduce it less. And I would just decrease the reduction on the bevel gears.
Unread 12-08-2011, 17:54
With all due respect, if you can't figure out gear ratios, you really should not be designing a swerve drive.
Unread 12-08-2011, 18:33
FRC #2220
With all due respect, I didn't post myself on this website, I posted my design. If you have a comment or criticism about that, I'd be happy to hear it. But if you only want to discourage me from experimenting and learning, I'd prefer if you kept that to yourself.
Unread 12-08-2011, 18:51
Aren_Hill's Avatar
Build Nifty Things
From looking at it, you have a fairly robust looking module with most of the issues attended too, aside from that bevel gear looking tiny.
What i'd be concerned with in this module is the amount of power necessary to steer those wheels (depends on the number of modules and what motors are steering).
Also depending on your steering arrangement some method of angle adjustment between the steering sprocket and the module may be necessary.
Do you have the machining capabilities to make that one piece bracket and securely mount it to the vertical support?
It also looks rather huge, but i like small compact packages if you look at our recent swerves.
Chris's statement has some merit, and I've learned to like when people are straight up blunt with me, as it makes things much easier to gauge and get a realistic evaluation of your current state.
I would suggest listening to his advice and getting a firm grasp on gear ratios and the efficiency of various methods of power transmission, this will only help your design. Exercises like this are a chance to develop further, and as has been pointed out you could use some work in the gearing arena.
Don't immediately think someone is attacking you when in reality they're just trying to bump you back to the path you've strayed from. He gains nothing from tearing you down.
A guy who likes robots.
Unread 12-08-2011, 19:25
FRC #2220
Thanks for the advice. As far as my previous comment is concerned, I understand the need for blunt criticism. I understand that Chris was trying to explain I need to better understand gear ratios, and I agree with him. However, I'm slightly taken back that anyone in FIRST would discourage someone from trying something new, especially when those new and difficult things are a source of the knowledge so vital to their own creation. Moreover, the criticism wasn't followed by an attempt to teach me the skills I need, or even show me where I could find the materials to teach myself.
As far as the module is concerned:
-The module is designed to be tied (via 25 chain) to the other three modules. (All I know is a banebots motor was used to rotate, but I wasn't in charge of that system, so I don't know how much power was needed. We also used 1" wide wheels, and rotating wasn't a problem)
-following some earlier advice, I'm working on interfacing a more robust and larger set of bevel gears.
-We do have access to the machining necessary to create the lower chassis.
-The size may be deceiving, but the wheels are only 3" in Diameter and 1/2" wide. I don't know if that still constitutes a "large" design, but if it does, I'd sure like to see Winnovation's swerve design
Thanks!
Unread 12-08-2011, 20:05
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
Not everything you want is going to fall into your lap, sometimes you have to go get it. The world belongs to those who show up. In this case showing up might mean searching CD's White Papers for JVN's Design Calculator.
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 12-08-2011, 21:59
I might be concerned if this was week 2 of the build season, and you were only then figuring out how to do design work with gears. (That would be the time to drop everything and assemble the kitbot.) Instead, it's the summer, which is the perfect time to figure all of this stuff out.
Unread 12-08-2011, 23:46
DonRotolo's Avatar
Back to humble
FRC #0832
My concern with the dual wheels is that every turn guarantees one or the other will have to scrub, and hard - based on my assumption that the wheel axle is solid and common to both wheels.
Unread 13-08-2011, 03:05
And incidentally, it was posted above that the JVN gear calculator would give you 7 ft/s. That's probably a decent estimate, but it's worth discussing some of the theory behind that result.
First, you take your wheels, which are designed to be Ø3.00 in. (From examining that drawing by eye, based on the size of the CIM, which is Ø2.50 in, I'm guessing the wheels are actually slightly larger than that. Did you account for the thickness of the tread backing, and maybe some of the tread?) We'll stick with Ø3.00 in for simplicity.
Then find the circumference per revolution: C = π × d = Ø9.42 in/rev = Ø0.785 ft/rev. That's the distance the wheel travels in one revolution. Though I'd really rather work in SI, it would just confuse the Americans—so were going to calculate the speed of the robot in ft/s.
That means we need rev/s, or its familiar cousin, rev/min. This is determined by the speed of the motor, at its operating condition. Note that this is distinct from free speed. Most of the time, when we talk about robot speeds, we're either talking about the theoretical free speed (when calculating), or the actual speed (when measuring).
Since the free speed of the CIM motor is ωfree = 5 310 rev/min = 88.5 rev/s, and we've got a 10:1 gear ratio (Z = 0.1) a little multiplication gives:
ωfree × C × Z = v
88.5 rev/s × Ø0.785 ft/rev × 0.1 = 6.95 ft/s
v ≈ 7 ft/s
In JVN's calculator, there's usually an arbitrary factor of 81% corresponding to operating condition (graphed on a torque curve)—in other words, the motor is operating at 81% of free speed. It's arbitrary in the sense that there's no physical reason why it has to be 81%, but based on JVN's testing and experience, it was a reasonable value. (I've occasionally picked a slightly higher value for this—around 85% or even 90%. Again, it was just a guess, but I've designed several drivetrains with lots of motors, which tend to be less heavily loaded under ordinary driving, so the motors presumably run closer to their free speed.)
In the calculations presented by Isaak* above, I think he's either using a 100% (i.e. at the free speed) calculation, inputting the correct speed and rounding up to 7 ft/s—in other words, using JVN's calculator to do the math I showed above—or else he's using the rough free speed JVN preloads it with (5 500 rev/min) and a weird speed loss constant of 97.25%. In any event, remember that the speed loss constant is just a way of saying "when the wheels are off the ground and spinning under power, their speed is 81% of what it would be in a frictionless gearbox." That's different from, but related to efficiency.
Anyway, in my estimation, your wheels are probably more like Ø3.25 in (due to the tread thickness), so that might skew things a bit. Using speed loss of 81% and efficiency of 90%, using 1.2 as the coefficient of friction, substituting in the correct values for CIM motors instead of the rough/old ones in some versions of the JVN calculator, and taking robot weight to be a rather plump 167.5 lbf (hostbot + minibot + battery + bumpers), I'm actually estimating that you'd see something closer to 6.10 ft/s and 201.0 lbf pushing force.
By the way, remember that all of this is predicated on your battery actually being able to deliver that performance—which it won't. As the load on the battery increases, its voltage drops, basically shrinking your speed curve (and hence your power). The more advanced versions of the JVN calculator will let you model motor performance over time at some voltage, from which you can determine the (constant-voltage) load on the battery. If the load on the battery is significant for a long enough period (e.g. when accelerating), it may be time to look at a few cases where the applied voltage is lower, in order to estimate mid- and late-match performance.
For now, though, don't worry too much about the battery voltage and power consumption, because your design isn't crazy enough for it to matter too much. (I've had a few designs where these absolutely did matter.) Estimate a desirable speed, then try to find gears to match.
* I just realized he's not "Hawaiian" or even "Hawaiʻian", but rather "Hawiian Cadder"...I'm not sure what to make of that.
