Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Unread 10-08-2011, 22:25
Aren_Hill's Avatar
Build Nifty Things
pic: Another fun Swerve Module
Unread 10-08-2011, 22:29
Re: pic: Another fun Swerve Module
Post the one with the violated window motor....
Unread 10-08-2011, 22:31
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Very interesting. Is the sprocket held in by those three screws I see acting like a clamping mechanism on the two opposite ends of the sprocket? If so, are you planning on anything if the sprocket does slip? At this point, that seems like the weak point in this design. But that could be solved by some ridges that fit into each other nicely.
Also, if you were to create this, would you use a keyed shaft, or hex? I only ask because in this render it looks like a keyed shaft.
Unread 10-08-2011, 22:39
Aren_Hill's Avatar
Build Nifty Things
Actually did the math on that clamping screw to disprove my architect father, and its got a safety factor of 2x on the max torque that ring will ever see before it theoretically would slip, of course a prototype would still be made.
It would be hex shaft, i just didn't finish it out completely
A guy who likes robots.
Unread 10-08-2011, 22:42
118 clamps in similar fashion, just with more surface area.
Unread 10-08-2011, 22:46
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Wait, 6wd swerve wasn't good enough for you? Now you have to do a 6wd WCD swerve?
1058 PVC Pirates 2016 - xxxx
Unread 10-08-2011, 22:59
Cyberphil's Avatar
That Guy
AKA: Phil
Excellent.
Beautiful stuff! Its inspiring me to test my CAD skills and design something along these lines.
Unread 10-08-2011, 23:03
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
:O, MIND BLOWNN.
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 10-08-2011, 23:06
Data Nerd
FRC #0079
I second this notion.
Unread 11-08-2011, 13:33
MattC9's Avatar
MattC9 MattC9 is offline
Violated Window motor? I want to see this
Unread 11-08-2011, 13:39
It was a joke really, Aren and I had been debating gearing for swerves and how the module rotation can be a handicap. There was one with like a 10:1 gear UP to make it super fast. Obviously this wouldn't work.
Unread 11-08-2011, 17:55
Cyberphil's Avatar
That Guy
AKA: Phil
Kind of like the teaser that one team posted with a all-traction-wheel omni drive where the base was milled out of one solid block of aluminium with the wheels directly driven by the CIMs.
Unread 11-08-2011, 17:57
Cyberphil's Avatar
That Guy
AKA: Phil
Unread 11-08-2011, 22:42
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
if only they had been able to design a mini-bot that fast...
