Go to Post when you think you are here to compete against other teams, thats when bad things start happening... - KenWittlief [more]
Unread 14-08-2011, 14:46
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: FRC973 offseason teaser #2
If you had a Dog gear with more teeth, like 6 (guessing by the gear on the far left). then the 4.5 lbs of force that the mini cylinder you posted might have enough force to shift a transmission. I bet those gears don't weigh much at all, but if they weigh less then that chain in your drive-train then there might be an advantage to using them.
