Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 15-08-2011, 18:21
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: pic: Latest Iteration of Swerve Module
3 bearings are supporting the drive shaft. There are two press-fit roller bearings in the lathe-turned hub which you can see holding the timing-belt pulley in addition to a single ball bearing press-fit into the actual structure.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
