Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Unread 24-08-2011, 11:31
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Automatic Tensioner
A spring as chain tensioner work great, when the chain is only being driven in one direction. Ask yourself these two things:
What happens when the chain is driven the other way?
How stiff would that spring have to be to maintain tension when the chain is driven in both directions?
Edit: If the ramp truly won't allow the sprocket to be pushed down, it'd work in theory. Assuming a coefficient of friction of 0.3 that would be around 16.7deg.
Idea: What if you put the idler sprocket on spring-loaded swing arm and prevented back-driving with a one-way roller bearing?
