Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 25-08-2011, 08:16
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Automatic Tensioner
Mentioning motorcycle timing chain tensioners reminded me of another automatic tensioning system! The engines that I have taken apart all used a timing chain system like this. I'm sure there are many other ways.
The slack chain guide side is tensioned by a hydraulic piston, as seen below.
You can see a linear ratchet and pall system on the piston's shaft to prevent the piston from back-driving and losing tension on the chain. Perhaps a spring or pneumatic piston with a similar ratchet and pall system would work well too... just more food for thought!
