Re: pic: Drivetrain Concept
Yes, Thank you for that advice, the interia is something that definitly will play a key factor. The choice for the smaller pistons was the fact they use less air then a single large piston. Also the individiual transmissions are used because of the slight boost in efficency and the ease of replacement and custom gearing ratios. However if we encounter difficulties with manufacturing custom gearboxes each side will recieve one AndyMark SuperShifter and that will slide in from the bottom.
Why would you switch from traction wheels to omni's? All other versions of this I have seen switched to mecanums. Also I recommend taking Jesse's advice; this drive is already hard enough, unless you're wildstang I'd try to add as much simplicity as possibly. (Wildstang would also go for simplicity, not because they have to, but because they understand it's importance, hence their awesomeness)
http://www.youtube.com/watch?v=RkR3GezFP14 Last edited by crazyStone : 26-08-2011 at 13:37. Reason: inserted link to video of progression |
Also, nice video Last edited by lemiant : 26-08-2011 at 14:58. |
Doing this all from scratch will definitely give you lots of great CAD practice. While people are mostly critiquing the design itself here, the model looks good.
As for the design, yes 148 had their "nonadrive" again this year, but it wasn't really. They removed the sideways omni wheel in the center that gave them omnidirectional capabilities because (I think) of the way their driver liked to do things. So this drive train will not be able to strafe unless you swap in mecanums or add a sideways omni wheel (or do something else). If you're going to have the gearboxes offboard, you really should combine each side. You will have half the gears and half the pneumatics, and you can use standard Super Shifters which make it waaaaaaaay easier to change ratios. Unless you go with mechanums. Then you need to drive each wheel separately. |
Yeah, like a power slide.
If I'm not mistaken couldn't this also be a 4 speed shifter?
With the two ratios on the gearbox than then the two different ratios given on the wheel sizes and reductions (don't know if they are synced).... Thats. Insane. I like it! - Andrew |
Just realized there was a mistake in the design concerning which Supershifter drove which side. A redesign is nessecary and taking place and should clear up some of the issues of the 2 transmissions. We are now attempting to link both front modules to one supershifter and both back modules to the other. Instead of the linking front and back on each side like it is now.
#10
<front> o o | | o o to this: <front> o-o o-o If that is the case you won't be able to turn. Last edited by lemiant : 29-08-2011 at 15:07. |
#11
good point
which represents the reasoning behind having 4 gearboxes. You limit mobility if you restrict the ways you can turn if you link front and back together. |
#12
I don't get it. You obviously can't have both front wheels and both back wheels together, because both sides are always doing the same thing, and you therefore can't turn. Also, if you try to make the front wheels do something different from the back wheels, you will just shred your tread (at best).
You CAN however have each side on one gearbox, and as already stated many times, there's no reason not to. Standard tank turning is accomplished by running each side at different speeds (or even different directions). |
#13
yes it can be done and its a good approach and it is our fallback, but if you want to run traction in back and omni in front you can't have different ratios because the wheel size is different whereas if the the gearboxes are seperated the speeds themselves can be altered and allow for the two different wheel sizes to work together.
