Go to Post Gracious Professionalism is a compass, not a set of calipers. It should be used to guide what you do rather than to measure it. - Alan Anderson [more]
Unread 26-08-2011, 14:54
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
Re: pic: Drivetrain Concept
Originally Posted by crazyStone View Post
148's drivetrain "nonadrive" is the base for this design, and they were pretty successful with using the traction and omni. Yes it can be simplified and it will be simplified but its more fun on cad to design it from scratch when you have the time, and gives good practice instead of just dropping in a STEP. file. Your advice on simplicity is appreciated, the design has been improved to allow much easier access to the modules. Since before the transmissions were IN the switching modules and that would have put a lot of stress on the metal frame of the modules.
http://www.youtube.com/watch?v=RkR3GezFP14
With Nona drive though, there was a 9th omni wheel perpendicular to the other 8 (hence nona). This allowed 148 to strafe. Seeing as it's just for fun, then go right ahead, I just wanted to check that you knew what you were getting into.
Also, nice video
