Go to Post Did you inform McMaster Carr that up to 3000 FRC teams would all be attempting to acquire a very specific spring ASAP all on the same weekend? - cgmv123 [more]
Unread 26-08-2011, 15:32
Aren Siekmeier's Avatar
on walkabout
Re: pic: Drivetrain Concept
Doing this all from scratch will definitely give you lots of great CAD practice. While people are mostly critiquing the design itself here, the model looks good.
As for the design, yes 148 had their "nonadrive" again this year, but it wasn't really. They removed the sideways omni wheel in the center that gave them omnidirectional capabilities because (I think) of the way their driver liked to do things. So this drive train will not be able to strafe unless you swap in mecanums or add a sideways omni wheel (or do something else).
If you're going to have the gearboxes offboard, you really should combine each side. You will have half the gears and half the pneumatics, and you can use standard Super Shifters which make it waaaaaaaay easier to change ratios. Unless you go with mechanums. Then you need to drive each wheel separately.
Unread 26-08-2011, 17:55
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
right, but their driver was able to sort of drift, which made it one of the fastest robots in turning around to place tubes.
Unread 27-08-2011, 01:04
on walkabout
Yeah, like a power slide.
Unread 27-08-2011, 08:29
Andrew Remmers's Avatar
AKA: Andrew Remmers
If I'm not mistaken couldn't this also be a 4 speed shifter?
With the two ratios on the gearbox than then the two different ratios given on the wheel sizes and reductions (don't know if they are synced)....
Thats. Insane. I like it!
- Andrew
Exploding Bacon 2007-2011
Unread 29-08-2011, 14:55
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
Just realized there was a mistake in the design concerning which Supershifter drove which side. A redesign is nessecary and taking place and should clear up some of the issues of the 2 transmissions. We are now attempting to link both front modules to one supershifter and both back modules to the other. Instead of the linking front and back on each side like it is now.
Unread 29-08-2011, 15:00
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
If I understand this right you're switching from this linkage:
<front>
o o
o o
to this:
<front>
o-o
o-o
If that is the case you won't be able to turn.
Unread 29-08-2011, 15:31
Cad posessed
AKA: Derek Stone
good point which represents the reasoning behind having 4 gearboxes. You limit mobility if you restrict the ways you can turn if you link front and back together.
Unread 29-08-2011, 15:39
on walkabout
I don't get it. You obviously can't have both front wheels and both back wheels together, because both sides are always doing the same thing, and you therefore can't turn. Also, if you try to make the front wheels do something different from the back wheels, you will just shred your tread (at best).
You CAN however have each side on one gearbox, and as already stated many times, there's no reason not to. Standard tank turning is accomplished by running each side at different speeds (or even different directions).
Unread 29-08-2011, 15:50
Cad posessed
AKA: Derek Stone
yes it can be done and its a good approach and it is our fallback, but if you want to run traction in back and omni in front you can't have different ratios because the wheel size is different whereas if the the gearboxes are seperated the speeds themselves can be altered and allow for the two different wheel sizes to work together.
Unread 29-08-2011, 20:30
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
You can accommodate different wheel sizes driven off of the same gearbox by gearing the wheels at a ratio (to each other) equivalent to the ratios of the wheel sizes. For example, if you have a 4inch and an 8 inch wheel driven off of the same gearbox, by having a 1:1 sprocket ratio between the output and the 4 inch wheel and a 2:1 ratio between the output and the 8 inch wheel they will run at the same ground speed. It is usually lighter to uses different sprockets to accommodate the wheel size difference than to use different gearboxes for the different wheels.
