Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
Unread 30-08-2011, 14:34
Re: pic: Cobra box
Just throwing this out there to make it easier -- Solidworks also has a little button its popup ribbon that says "View Mates". If you select a part on your render and then click the button, it lists all of the current mates for the part. Then you can edit/delete the mates as you see fit. Works wonders when doing distance mates for welded parts.
GitHub
