Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 25-09-2011, 11:49
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
pic: 2 Speed Switching Module
Unread 25-09-2011, 11:51
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: pic: 2 Speed Switching Module
I was just taking a look at this, and I had 3 questions:
1. Why such a large gear coming off of the CIM motor
2. What are the gear ratios and wheel sizes
3. What is the total weight
Looks great though, and it would be nice to see pics of the finished prototype.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 25-09-2011, 23:30
Cad posessed
AKA: Derek Stone
The large gear is inaccurate I had to throw it on there to represent how the power is transferred but there will be another gear in between the cim and gear shaft. That way we can gear it down to a desirable ratio instead of being geared up like it is in the render. The gear ratios are traction 1:48, 1:20. Omni 1:20, 1:8.3 . Those ratios can change slightly but most of the components are from andymark supershifters. The entire modules weigh 8 lbs a piece and their will be 4 of them. So they will be similar weight to a swerve module which we used this year.
Unread 25-09-2011, 23:39
Aren_Hill's Avatar
Build Nifty Things
You know most teams run the omni's at high gear speed and the tractions at low gear to accomplish effectively having 2 gears each optimized for the task at hand right?
148 drove the omni's at a high speed off the cim, then a chain reduction to the traction wheel for "low gear".
With the current setup it pretty much just looks like you're needing 4 extra pistons for not much in added features.
So basically do you need 2 speeds when in each mode? or will 1 speed optimized for each mode work.
A guy who likes robots.
Unread 25-09-2011, 23:43
Cad posessed
AKA: Derek Stone
The gearing ratios are in limbo because it was calculated to speeds for the specific gears. The tractions drive at 2ft/s with 60 ft/lbs of torque and the omnis drive at a max 10 ft/sec. For the prototype the team is only putting 2 modules on a frame and putting two tractions in back and with this configuration you could actually run it and have an effective tank drive with some additional torque benefits. The gearing allows for an even bigger ratio between traction and omni.
Unread 25-09-2011, 23:48
Aren_Hill's Avatar
Build Nifty Things
Do the math and see what level of torque your traction wheel is actually capable of transmitting to the ground, at 2ft/s you'll just make yourself move really slow and not have any more pushing power than someone who geared themselves right at traction limited.
Unread 25-09-2011, 23:55
Cad posessed
AKA: Derek Stone
Perhaps your correct but that's the reason for the prototyping and that kind of gearing ratio can be changed with the gearing from the cim which would not be terribly difficult to accomplish. The main goal is to see if the module can even withstand the stresses of housing the shifting mechanisms and continue to work properly and reliablely.
Unread 26-09-2011, 04:37
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
5 ft/sec is a common geared speed - there is a reason for this. You should at least layout both sets of gear ratios to be sure they are easy to switch.
Unread 26-09-2011, 04:38
You can prototype a low gear with a normal traction base. Just gear it down until the wheels slip in place when pushing against a wall.
Trust me, you will be a LOT happier if your prototype goes 5 FPS in low gear than not.
Unread 26-09-2011, 11:08
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
There is no "perhaps" in this case. You are limited to a certain amount of traction and thus possible force you can transmit to the ground. With that gearing you will not be able to transmit all that force so then you will just be exceptionally slow. Have a mentor with a physics background or at least some physics knowledge explain how to find the maximum force you can apply based on friction and normal force. It will greatly improve future designs.
Also like some people have already said, use the shifting of the modules to accomplish the gear switching. You have no need for 2 speeds on each wheel and it greatly complicates things and makes the entire module heavier.
One final comment is it looks like the gear on the traction wheel is a higher DP than the rest of the gears which is counter intuitive to typically accepted practices. The highest forces will be seen by that gear so typically you want that gear to have the lowest DP. Most teams run 20DP, .375 fce width gears in the final stage of a transmission.
Mentor 2415
Unread 26-09-2011, 19:05
Cad posessed
AKA: Derek Stone
Yes I understand there is a limit for the amount of torque that can be transmitted through the wheels. I have had a year of physics and am in AP physics now. The reason I used perhaps, is the fact of weight distribution and the surface area of wheels and material used all play into the how much of that torque can be distributed. Perhaps a configuration can be made that 3.5 ft/sec still transfers torque effectively through the wheels. That is the reason for the prototyping, in addition if we can successfully create the modules with gearing inside of them; it should be much easier task to create modules without switching speeds. This is merely a prototyped design that is being constructed. There is no belief that it will work flawlessly or be a great improvement it’s more of skill building project for preseason. The gear ratios have been made smaller in consideration for what everyone on here has been saying, the low speed has been moved up to nearer 4ft/sec.
I am also confused on which (higher dp) gear you are referring to? There are no gears attached to the traction wheel. That is driven by chain and sprocket from the omni. HOWEVER you are correct that the omni has a higher dp gear (which is what I believe you were referring to), the reason for this is very simple. It is very hard to get 5.5" diameter gears that have the proper bore size and thickness. The reason for such huge gears, Mentors have strongly discouraged the use of chain to connect the switching gear shaft to the omni wheel (their reasoning still escapes me). The design was modified to accommodate this request.
Unread 26-09-2011, 19:57
artdutra04's Avatar
VEX Robotics Engineer
The first stage reduction (between the CIM motor and shifter cluster shaft) looks like it's geared faster. Don't do this in a gearbox if your intention is for the output to be slower. Gearing faster in one stage only to gear slower later is just wasted weight, space, and lowered efficiency. Instead, do like AndyMark does with a 12t pinion on the CIM motor and a 40t gear on the shifter cluster shaft.
As for the higher DP gears on the shifter output, if you could fabricate a gearbox to accurate enough tolerances to properly mesh the 20DP AndyMark shifter gears, you can easily use 25p roller chain or timing belt instead of the higher DP gears.
Art Dutra IV
世上无难事,只怕有心人.
Unread 26-09-2011, 20:30
AKA: Sean
Didn't even realize the gearing up and then back down. Additionally, how is the CIM getting attached in the module and is there going to be any type of cross bracing?
Mentor 2415
Unread 26-09-2011, 21:48
Cad posessed
AKA: Derek Stone
sorry but its posted above in this thread, that cim gear is for representation of where the connection is, and is NOT an accurate representation of the actual gearing size connecting those two shafts. Due to time constraints and hw i was unable to get that fixed yet. yes but our mentors will not approve the plan if it has roller chain. We suggested that but I guess previous bad experinces lead them to shy away from using chain. I think chain would be easier/cheaper/ and actually lighter than a 5.5" x .375" gear even with speedholing.
Yes there is a top sheetmetal piece that hold the sides apart and then bracing is brought up to support the cim perpendicular to its output as well as parallel to its output. Due to changes in the design from what I posted just a few weeks ago, theres been inadequete time to flesh the mounting specifics for the motor.
Unread 27-09-2011, 08:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Refusing to use roller chain is silly... It will most likely be cheaper and lighter than gears, and being pre-season this is the perfect time to learn how to use this drive mechanism that is a staple component of FRC.
