Go to Post Nice going guys!! Not only did you succeed in reviving this thread, but you woke up Dave from his mid summer slumber. Now we are going to get 6 months of pre-kickoff torture!! - Rosiebotboss [more]
Unread 28-09-2011, 07:11
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: Sorta WCD
I am currious as to what ratios are in those dewalts. If i remember correctly it is something like 1-12, 1-16, 1-42. what ratio are you thinking of using for the chain, and what fps does it go?
Unread 28-09-2011, 08:02
Re: pic: Sorta WCD
I believe with CIMs most people remove a stage to make the transmissions run at 1:3 1:4 1:12.
Unread 28-09-2011, 09:00
AKA: Isaak
Re: pic: Sorta WCD
Ahh, that is correct, My experience is with a dewalt and fisher-price pairing.
This also makes a lot of sense because the first stage is held together largely by the plastic casing, while the deeper in stages are much more secure.
Unread 28-09-2011, 15:53
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: pic: Sorta WCD
Just to clarify the ratios on the dewalts with the first stage removed are 12:1, 4:1, and 3:1. These are further reduced by a 22:32 sprocket reduction giving speeds of 5, 13, and 17fps (Thank you JVN for your design calculator). The chain is run past 2 idlers to put the sprocket on the drive motor in the right place to only use 1 chain rather than one for each wheel.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 28-09-2011, 18:47
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Sorta WCD
Wait, one chain per side or one chain per motor and the 2 closest wheels? While the latter sounds fine, I would not advise the former due to the fact that a single failure would render the robot un-steerable. If two chains are used per side, on the other hand, there is at least some degree of redundancy.
Unread 28-09-2011, 21:08
iScout
Re: pic: Sorta WCD
1 chain per dewalt, which makes it 2 per side
