Go to Post Proof: Remove the motor from it's mechanical house of bondage and it will operate just fine - Mike Betts [more]
Unread 28-09-2011, 13:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: The Bobcat 2011
Are you able to join the flat urethane belting without using whatever special kit McMaster recommends? When we use round urethane belting, we just heat it over a heat gun and mash the malleable ends together, then grind the flashing off. This is very easy and doesn't require anything particularly expensive.
I'd like to play around with the flat belts some, though, if they're similarly easy to work with.
Did you just let the belts wander back and forth on the drums? Any problems with them riding up on one another?
--Madison--
...down at the Ozdust!
