Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 28-09-2011, 15:53
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: pic: Sorta WCD
Just to clarify the ratios on the dewalts with the first stage removed are 12:1, 4:1, and 3:1. These are further reduced by a 22:32 sprocket reduction giving speeds of 5, 13, and 17fps (Thank you JVN for your design calculator). The chain is run past 2 idlers to put the sprocket on the drive motor in the right place to only use 1 chain rather than one for each wheel.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 28-09-2011, 18:47
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Sorta WCD
Wait, one chain per side or one chain per motor and the 2 closest wheels? While the latter sounds fine, I would not advise the former due to the fact that a single failure would render the robot un-steerable. If two chains are used per side, on the other hand, there is at least some degree of redundancy.
Unread 28-09-2011, 21:08
iScout
Re: pic: Sorta WCD
1 chain per dewalt, which makes it 2 per side
