Go to Post GDC.... Come on. Counter-clockwise? ... I believe NASCAR might file a lawsuit! - Pavan Dave [more]
Unread 10-14-2011, 12:44 AM
Andrew Lawrence
Drive train idea
Anyone ever tried this? A four wheeled robot that uses Ackerman's steering, but has mecanum wheels, all powered. Would this be good, bad, what?
Unread 10-14-2011, 01:13 AM
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
Re: Drive train idea
A good thing to do when thinking about designs like this, ask yourself "what do I gain?"
Unread 10-14-2011, 02:33 AM
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is online now
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
With mecanum drive, you have 3 degrees of freedom. X Translation, Y Translation, rotation
With ackerman drive, you have 2 degrees of freedom. Y translation, rotation about a certain point(determined by your wheel and structure geometry).
It seems like you will be losing a degree of freedom for what gain?
My 2 cents...
Jeremy
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 10-14-2011, 08:09 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Admittedly, I haven't done the math, but it seems to me that if mecanum wheels are not parallel to each other, they lose all their superpowers.
-edit- What if they're set at 45* angles relative to the frame a la killough so the rollers are in line with the robot?
Hi!
Unread 10-14-2011, 08:17 AM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Ackermann is just a subset of 3DoF control.
Unread 10-14-2011, 09:19 AM
Andrew Lawrence
Ok, thanks! We were mixing different wheels and drive trains at yesterday's meeting, and this seemed like a combination we yet to have seen. Our vision was a car-like robot that could swerve around corners and the straighten its wheels and move sideways. Just something for the off season.
Unread 10-14-2011, 09:28 AM
Data Nerd
FRC #0079
Sometimes there is a reason you haven't seen something done.
Consider looking to 2008, several interesting drive systems came out of teams that year. Of particular interest to you might be 65's ackerman and the 'twitch' drive system. (CDM search the tag 'twitch' and you should find it)
Part of my objection to a system such as you described would be complexity of code for little benefit. When mecanum wheels are fixed you already have 3 controllable degrees of freedom. Their behavior is very well known (thanks, in no small part, to Ether). The issue is that once you start rotating the wheels you add significant complexity into the calculations while not adding any real value (You don't gain additional DoF and, it could be argued, you actually lose capability due to additional weight and use of an additional motor).
Unread 10-14-2011, 09:45 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
If I understand you correctly, you could accomplish this with two pairs of steered wheels.
Unread 10-14-2011, 11:02 AM
Ether's Avatar
Rookie Year: 1969
Start with a standard mecanum wheel arrangement (Figure 1).
Swap the left&right rear wheels (Figure 2).
Toe-in the front wheels and toe-out the rear wheels (Figure 3).
Now you have a vehicle that can drive forward and backward (powered by rear wheels only), and has front-wheel steering, but cannot strafe effectively. Not an improvement.
Name:	mecanum 45 wheel.gif
Unread 10-14-2011, 01:42 PM
Racer26 Racer26 is offline
Twitch came from team 1565 in 2008. It was called the linkage drive, and it was a 4 omni-wheeled robot, and the linkage would switch the wheels from pointing N/S to E/W. Switching at speed resulted in significant coasting in the direction of initial travel, creating arced movements around the racetrack.
Look for pictures from Waterloo or Greater Toronto to see it. 1565 is currently defunct, having not competed in the 2011 season.
Unread 10-14-2011, 08:29 PM
Andrew Lawrence
But it wouldn't be as cool!
Unread 10-18-2011, 11:33 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
But it wouldn't be as heavy or complicated!
FTFY
