Go to Post You'd be surprised how many teams don't read the rules period. - Koko Ed [more]
Unread 08-11-2011, 14:48
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Re: pic: FRC488's Octocanum Ver 2.0
We tried a number of filters (Kalman was unfortunately beyond my reach, never had a strong grasp on linear algebra), but they turned out to be unnecessary - the gyro we used (don't have the model # on me) was incredibly accurate - it usually only drifted ~3 degrees over the course of each match, even through collisions.
The "stationary detection" we did was only necessary when the robot was put on the field but the start of the match was delayed several minutes (yeah, we've all been there).
Unread 08-11-2011, 14:52
Mind sharing the model number of that gyro?
Also, you didn't use the pair of follower wheels to try to determine rotation rate while translating, you just used it to detect the complete absence of velocity, correct?
Unread 08-11-2011, 15:04
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The point midway between the translation follower wheels was said to be the center of rotation of the vehicle. To the extent that is true*, you could extract vehicle rotation while translating.
*The center of rotation likely shifts around especially if weight distribution changes as manipulators move.
Unread 08-11-2011, 15:08
Wouldn't that only be true while not translating? Translating would shift the center of rotation, would it not?
Unread 08-11-2011, 15:26
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
What's the maximum speed at which you can switch between Mecanums and high-traction wheels? Plus, about many switches can be performed before there becomes a serious air deficiency such that it is unreasonable to switch at all, assuming you have about 3-4 tanks at 120 PSI at the start.
Attending: MN Duluth Regional
Unread 09-11-2011, 19:34
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
YMMV, but we used 1 tank, (2) 1.5" bore, 2" stroke cylinders to switch between traction & mecanums, (2) .75" (6 or 8" stroke) to lift claw, and 2 small cylinders to deploy the minibot, and never had a want for more air.
Unread 08-11-2011, 15:56
Ether's Avatar
Rookie Year: 1969
Imagine a robot going around a circular track at constant speed such that it completes one lap every minute. The robot has a gyro mounted on it. The gyro rate will be 1 rpm, the same as if the robot were spinning in-place at 1 rpm.
I'll have to check the math, but I believe that with 3 followers mounted as shown, you can extract the vehicle's rotation rate (the same rate measure by a gyro) for any vehicle motion.
Unread 08-11-2011, 15:59
Yes, but that's with 3 follower wheels. 488 only has two follower wheels measuring the floor, so I was clarifying as our swerve has two and there is no way we could infer rate from that (in fact we have to factor in the gyro rotation rate to even to get an accurate linear velocity).
EDIT: 488 actually has three follower wheels in that diagram, I was mistaken. Trivial calculation in that case.
