Thread Tools |
Rating:
Display Modes |
Re: pic: FRC488's Octocanum Ver 2.0
How about it, John? :-) |
The Discobots used the kit gyro last year to do field oriented drive on our omni-drive. We didn't have to much issues with drift over the duration of the match. We did have it setup so that the driver could zero the gyro him self at any of the cardinal directions but he only needed to use it in a few matches.
Our biggest problem with the kit gyro was the initial calibration routine we were dead in the water during a few elimination matches at Lone Star because we didn't let the robot sit still when we turned it on. |
I've sent an email to the electrical lead on our team, I'll let you know once he digs up the model number of our gyro. =]
We did that for a time, but it turned out the finer resolution was overkill and a bit noisy. The lower resolution (500 deg/sec max output) was accurate enough.
Actually, I thought the gyro was broken, because sometimes it wouldn't drift at all for long periods of time. Then I'd kick the robot and see it respond. The gyro combined with the default gyro libraries from WPI worked pretty well. |
1. The bandwidth of the gyro as implemented on that evaluation board. 2. The "auto zero" function, which apparently uses Vref to provide a dynamic estimate of what the true bias is (if you used this feature) Last edited by Jared Russell : 10-11-2011 at 08:36. |
Sorry for taking so long to reply -- I've been pretending to be very busy. Let me try to address some of the non-programming-related questions.
1. It uses a KoP frame as its main frame, but nothing else is really from the KoP. 2.
3. This should be very easy to assemble, generally speaking. The most difficult parts to deal with are the wheel module sides. Last season, we used 2x1x.125" channel there, but because the gearbox was driving the mecanum wheels via chain, everything was a dead axle. Here, the mecanum is driven via live axle and thus requires bearings in the wheel module sides so that the plaction wheels can be rotated down efficiently. The manufacture it the way I've shown, you'd need some ability to CNC plastic/aluminum or otherwise to mill accurate bearing pockets. 4. Maybe. There are still details absent from the model. If I ever get those in place, I'll share the CAD models. Quote:
It's possible to drive the pivoting wheels first, I'm sure, either by allowing the entire gearbox to move when the wheelsets actuate or by devising a system that allows the chain length to vary as the distance from gearbox output to wheel changes. I've done the latter (about ten years ago) and would rather avoid doing it again. The former is probably achievable, but I feel that it'll complicate the frame design more than I'd like and we didn't have discernable trouble last season with rigidly mounted mecanum wheels, so I'm happy to do it again. Quote:
