Go to Post I have no clue. All I know is that every year the riddle in the clue has confused me but this year it is the lack of confusion that confuses me. - hallk [more]
Unread 16-11-2011, 10:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Uber3.0 - prototyped
Originally Posted by Brandon Holley View Post
In high gear this past year, we were moving faster than this (actual speed). It required some pretty sophisticated control software that 254 helped to develop. Once we had this setup, it made driving at that speed much simpler.
I would not recommend trying to drive that fast without some software support. I think a simple 2 stick, or 1 stick drive setup would be quite difficult to handle. However, every driver is different, so YMMV.
-Brando
Care to elaborate about what it did? Balance wheel speeds using encoder feedback?
Unread 16-11-2011, 13:51
Brandon Holley's Avatar
We utilized both encoders in the drive system, and a gyro.
We basically just elaborated on Cheesy Drive. 2 stick drive system- 1 stick is essentially "throttle" the other stick is essentially "steering". There was a button on each stick. One button for shifting, the other button for "quick turn". Quick turn essentially turned the steering stick into a single stick drive system for turning in place.
As we traveled at a faster rate of speed, the gains in the turning loop would adjust so that dumping the steering stick all the way to one side or the other would create a smooth, controlled turn. This occurred even at 16+ ft/s top speed when we traveled back and forth across the field. Additionally, even at low speeds, the robot could only turn in place using the quick turn button, otherwise it would drive in a small arc.
I did not do the actual coding of it, so I'm speaking more from a theoretical/design point of view, but that's essentially what it did.
Driving without this setup at top speed was quite difficult. We noticed right away as our driver began driving just the drive system in week 3 or so. He practiced driving the full field and then dipping into/out of the human player lanes over and over again. We continued to tune the system until he felt it was solid, and we were satisfied with the results.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-11-2011, 11:11
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
So, if I'm understanding you correctly, turning rate limits were controlled based upon the speed of the robot.
That does seem like it would make the robot easier to control. I also like the idea of a "quick turn" button too. I assume that made the robot to a very fast about-face?
Unread 17-11-2011, 14:01
That is correct. As the robot moved faster, the turning became less "sensitive". It essentially allowed the driver to still use coarse controls to maneuver at high speeds.
Quick turn would change the control scheme to allow turning in place. If you held the button down and moved the stick left and right, you essentially created the control scheme you get from moving one stick forward and the other backward in a standard 2 stick setup.
-Brando
Unread 17-11-2011, 14:09
-Brando
Just to clarify, this means turning in place is exclusive to quick-turn, and in all other modes turning is in arcs?
Unread 17-11-2011, 14:23
That is correct.
