Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 02-12-2011, 15:56
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: pic: FRC488's Octocanum Ver 2.0
First off--very nice design, and very accessible. We're not very capable in terms of build complexity, but might prototype something like this next season.
One of our main concerns is the side loading.
The subframe, right now, is 1x1x.125" angle bolted to the perimeter of a .125" perforated PVC sheet and hung from the Toughbox Nano housings. It is intended to hold electronics and would need to be enhanced if it were going to see more substantial loading.
Is this also intended to handle some of the sideways forces that the wheel assemblies would encounter if a robot hit from the side while in traction mode? It appears that the subframe and wheel assembly are flush, so I assumed that was an additional purpose?
If I recall, from octocanum v1.0 I saw video of you testing side loading by deploying traction while strafing. Did you run into any problems with this during last year’s competition?
Unread 26-03-2012, 20:00
pfreivald's Avatar
AKA: Patrick Freivald
I wanted to resurrect this thread to say the following to Madison:
THANK YOU SO MUCH!
We based our octocanum on your design for this year, and it's the most successful, awesome drivetrain we've ever built. We absolutely, completely love it -- and based on the feedback from a lot of other teams, many other people do, too. It is, hands down, one of the reasons we were as successful as we were this year.
Thanks again!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 26-03-2012, 20:26
lcoreyl's Avatar
AKA: Milner
THANK YOU SO MUCH!
Thanks again!
Wow, I guess this should push us over the edge and get to work on this. Man, I'm kicking myself for not prototyping so we could have used it this year.
I could probably guess due to your absolute love, but did you encounter any serious side loading during competition? (That will save Madison from needing to bother so she can go work on her next bit of magic!)
Unread 26-03-2012, 20:56
pfreivald's Avatar
Nope. We made sure to use steel pods so that side load would be adequately dealt with -- and it was tremendously robust over two regionals where we played massive defense, crossed the barrier 1+ times a game, and did lots of bridge balancing. The only malfunction was losing tread on an AM performance wheel, and that hardly counts. (Even with only three treaded wheels, we humped across the barrier that last game.)
Team 1551
I write books, too!
