Re: pic: FTC290 2011-2012 Mast
Have you measured where the system's center of gravity resides once the mast is extended (the system includes the two crates). I suspect that an incidental bump from another robot or a bowling ball has a good chance of tipping the entire system onto its side. That would be a bad thing during a match. |
Thats impressive. Any video of it driving around with the mast all the way up?
I wouldn't be too worried about the stability, as long as you don't move with the mast extended.
Good strategy. |
I don't think it would be too hard to attach some passive stablizers which flip out when the arm extends up. That would probably help a lot if your concerned with tipping and don't plan to move after raising the arm.
Very Cool, this is the highest I have seen a robot extend so far. |
This bot isn't competing in any other events this year. 290's qualifier was last Saturday, which they made to the semifinals, but were unable to advance to states. |
Great job guys! Can 987's mentored team borrow it???
But seriously...I would love to see a close up of your elevator/slide mechanism. |
How long does it take to reach full height?
Well, the mast is attached to an arm that will pick up the crates from behind the bot, and then you have to line it up before you drive the mast. I'd say it takes about 10-15 seconds to do all of this, and get the mast to full height.
