Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 13-12-2011, 15:41
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 816's 2011 Off-Season Teaser
Originally Posted by rcmolloy View Post
Oh I see where you're going with this one Dustin. The topic that we were discussing about makes sense then.
...Or just give them to me for hand delivery dude. We don't live that far away.
Hehehehe. I don't know if you're fully aware of how ridiculous our current project is.
Originally Posted by Brandon Holley View Post
I've been making a variation of the press-fit Colson hub since 05 using the same principle. If I'm seeing the hub correctly, it looks like its knurled which is something I've had great success with as well.
Looking good.
-Brando
Brando, Technically the hubs aren't knurled. The grooving that is visible in the picture was done by running a tool at a relatively high rate across each plug. Technically, it's not the right way to create a strong press because the cuts are in the same direction as the wheels would see force but I'm very happy with the results so we'll probably just stick with this method since it's easy for our Lathe guy to knock out - and it's pretty easy to replicate in house with minimal skill/effort.
For season I see the resources used to make the double sprockets better used elsewhere, and instead just purchase off the shelf sprockets.
Adam, you're right on the money with this. I doubt we'll do a run of double sprockets again unless they're absolutely needed or it makes sense to do so.
This entire project is heavily influenced by a few factors:
-We wanted to try some new construction methods.
-We wanted to build a lighter more competitive drive than what we used in 2008.
-We wanted to move to an 'assembly' style build method.
-The shop foreman at our machine shop told me to design something 'interesting' for his guys to make - one thing lead to another and yeah....
Here are some more pictures for those of you that are interested:
-Dustin Benedict
