Go to Post Reading the directions is as important as reading the manual. - the man [more]
Unread 14-12-2011, 09:01
Brandon Holley's Avatar
Re: pic: 816's 2011 Off-Season Teaser
Originally Posted by thefro526 View Post
Brando, Technically the hubs aren't knurled. The grooving that is visible in the picture was done by running a tool at a relatively high rate across each plug. Technically, it's not the right way to create a strong press because the cuts are in the same direction as the wheels would see force but I'm very happy with the results so we'll probably just stick with this method since it's easy for our Lathe guy to knock out - and it's pretty easy to replicate in house with minimal skill/effort.
Ah- yes the mental picture popped into place. Knurling is really REALLY simple (and pretty cool). It could be something you guys experiment with now, especially since you already have the lathe, etc.
The gearbox plate looks good. I assume bearings will be pressed into it. I'd be curious to see what results you get as far as the tolerance on the press fit from a waterjet. We've had access to a waterjet for a while, and we use it for a lot of things. One thing I've always been wary about is bearing holes though. We usually will cut out almost the entire part and then go back to correct the bearing holes with a secondary process.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
