Go to Post If no hint or advanced BOM don't come out, will it make you not participate in FIRST this year?? - Elgin Clock [more]
Unread 15-12-2011, 18:53
Ninja_Bait's Avatar
AKA: Jake Potter
FRC #0694 (StuyPulse)
Re: pic: Team 3647 West Coast Drive
Originally Posted by JamesCH95 View Post
Care to elaborate on that? For example, I'd find it very hard to believe that a 1/4" pop rivet (steel or aluminum) is better in shear than the shank on a graded 1/4-20 bolt.
A properly designed and setup bolted joint can sustain more shear loading than the bolts themselves alone. The friction between the two parts, as generated by the clamping load of the threaded fastener, carries a substantial amount of load in addition to the bolts. Can the same be said for rivets?
I looked it up: Pop Rivets vs. Bolts
These are two kind of arbitrary sources, but it shows that while rivets are not quite as strong, they're comparable. The steel 1/4" rivet (shear: 2750 lbs.) beats Grade 2 1/4" bolts (shear:~2200 lbs.). However, the higher grades outmatch the rivets by a lot.
