Re: pic: Wide base robot CAD
Also, even the 8 inch wheels could probably move outwards at least an inch. On another note, make sure you don't block the fans on those Victors. I've never seen one catch fire, but I'm sure if they're too close there's a good chance of it happening. Last thing: Is the frame 1/16" aluminum and do you plan to weld or use bolts and brackets? |
Yes, the victor fans should have clearance, but when spacing out the victors also take into consideration of the connections and accessibility of all of the connections. It would be easier to wire and trouble shoot. Also, is there any reason you decided to put the CRio on its side? If you had it vertical it does take up less of a footprint and lets you access ports from multiple sides easier.
The only other time i've seen a victor fail was when a piece of PWM wire broke of inside it and shorted something out. |
