Re: pic: Wide base robot CAD
Yes, the victor fans should have clearance, but when spacing out the victors also take into consideration of the connections and accessibility of all of the connections. It would be easier to wire and trouble shoot. Also, is there any reason you decided to put the CRio on its side? If you had it vertical it does take up less of a footprint and lets you access ports from multiple sides easier.
