Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 15-12-2011, 23:40
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
Re: pic: Wide base robot CAD
Originally Posted by Allen B. View Post
Yes, the victor fans should have clearance, but when spacing out the victors also take into consideration of the connections and accessibility of all of the connections. It would be easier to wire and trouble shoot. Also, is there any reason you decided to put the CRio on its side? If you had it vertical it does take up less of a footprint and lets you access ports from multiple sides easier.
The cIRO is on it's side due to the fact that I was aiming to make this drive base vertically compact. I've got the strangest feeling that this year will be a limbo year. The whole design will be reworked if it comes to fruition so that the robot can be built around the game strategy and not the other way around.
