Go to Post Really let's not remove the best part of the games and that is the human interaction with the robots. Humans are much more adaptable and interesting when it come to problem solving. - Steve W [more]
Unread 18-12-2011, 13:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Team 3647 West Coast Drive
Originally Posted by Basel A View Post
Is the block+plates design better than just the plates at holding the bearing axes collinear just because of the added material constraining the bolts, or is there a more complicated explanation?
The bearings are pressed into the same bore, so they are definitely coaxial.
I think that if the slots are cut in the frame rail that the plates become superfluous. Mk. 32, you may consider using flanged or heavy hex bolts and/or washers and omitting the side plates.
