Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Unread 19-12-2011, 14:30
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Team 3647 West Coast Drive
McMaster # 9056K11 (or similar from a less expensive supplier) might be a good start for Richard's design.
Without a DRO, how would one check the bored diameter? Is the only way to start/stop the lathe constantly?
Even with a DRO one would stop the late occasionally, i.e. after several passes, to check the ID of the part. Without a DRO one does the same procedure. The drive handles on the lathe will have a scale on them, something like 0.100" per revolution, typically with 0.001" accuracy. The operator would then count.
I like to take a 'skin' cut, measure the ID I just machined, subtract from the ID want to reach, and count turns/notches on the drive handles.
Edit: Chris' suggestion is also a good one. Assuming you're going to make many holes that size it is definitely worth investing in a reamer.
