Re: pic: Sheet Metal Chassis Prototype
Increase the flanges on the front and back to add more metal. Consider bending another return flange. Select the aluminum type: 1100, 3003, 6061-T0-T6 or 5052-H32 then check you minimum bend radius with the people who are going to bend your parts.
Needs a integrated belly pan to stiffen the chassis. Add some joggles on the length to make it stiff. Consider a separate electronics panel so you can preassemble your electronics
Don't forget the mounting points for the manipulator.
Needs quick release bumper brackets and battery box
Add clearance through holes to tigthen the CIM on the transmission.
Loctite your nuts before competition.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
