Go to Post I need someone to kick me out...unfortunately that would have to be me... - Mark McLeod [more]
Unread 20-12-2011, 11:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Sheet Metal Chassis Prototype
Originally Posted by Timz3082 View Post
Thanks for the feedback!
the gearbox is a toughbox mini with a 10.7:1 ratio built into the 1/8"" aluminum, this is a bit more reduction than we had last year and it worked great! by great, I mean we though it was the 2nd best drivetrain on the field! (2nd to 141 who had some crazy hyperspace swerve drive which after looking at for about 10 minutes, I still couldn't comprehend! I will now work on the modifications making this a more feasible, and realistic design! For the belly-pan, would there be anything wrong with using 1/2" Birch Plywood? It would be lightened and might end up lighter than aluminum, I will find out!
I like 1/2" birch plywood, 95 has used it in robot frames for year. I would highly recommend it.
