Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 20-12-2011, 15:50
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Re: pic: Minimalist Robot Concept
Originally Posted by kaliken View Post
I have already added it to our teams part library. I did a bit of searching on the NI website. You can find the cRio on the NI website search for cRIO-9075
I will get a link when I find it again.
http://digital.ni.com/hardref.nsf/we...2578b600581217
The main reason we built our own model was to reduce the size. Last year, the 8 slot cRIO model was 73MB and it was imported so it couldn't be modified easily. I downloaded the 4 slot cRIO from your link and it's 41MB. It is a native Pro/E model so maybe it could be defeatured. The model shown in the render is only 6MB.
EDIT: The part file on the NI site is just for the commercial version of Pro/E.
Originally Posted by Taylor View Post
[troll]
It'd be a lot better if it didn't have mecanums
[/troll]
I knew you'd come around.
Unread 20-12-2011, 16:54
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
Originally Posted by Alan Anderson View Post
Mecanum wheels don't work very well upside down.
If my understanding of Mecanums is correct they work fine, just not quite the same. An upside-down toggle could be implemented to change the code (like it was on many battlebots) and driving should continue as normal.
Unread 21-12-2011, 00:21
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by lemiant View Post
If my understanding of Mecanums is correct they work fine [upside down], just not quite the same.
Nope. If upside-down mecanum wheels are approximately in a square, the robot won't be able to turn in place under its own power, and it will be easily spun by pushing it.
Unread 21-12-2011, 00:29
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Unread 21-12-2011, 00:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by PAR_WIG1350 View Post
This bot looks like it's quite a bit out-of-square, so it would be possible to generate some rotational torque when upside down.
See page2 of this PDF.
Unread 21-12-2011, 00:47
Software Architect
The proposal was to move the wheels out and make room for the cRIO between the gearboxes. That would have made it quite a bit more square.
Unread 21-12-2011, 06:26
I love this about FIRST - even something that started out as pure silliness can turn into a legitimate discussion.
Unread 21-12-2011, 08:02
nathannfm's Avatar
AKA: Nathan
FRC #3940
I hate to be a debbie downer...but I think you are going to need some bumpers lol
Unread 21-12-2011, 08:09
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Not if this is a placebo bot!
Hi!
Unread 21-12-2011, 16:55
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Or the minibot for next years game
End Game: Baby Overdrive field in the center for the minibots
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 21-12-2011, 17:53
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
complete with mini overpasses
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
