Go to Post "Everything is possible. Just depends on how much it costs and how much physics you have to apply..." - Kimmeh [more]
Unread 22-12-2011, 00:32
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: Team 3266 CAD project
Originally Posted by akoscielski3 View Post
When designing a chassis i've always tried to line the wheels up. I dont know if it makes a difference at all though. Im not saying you should line them up, but does anybody know if lining the wheels up vs letting them be off make a difference in performance, or efficiency?? Thanks
179 and 234 have both used offset wheel 6wd several times with good success. I don't know that it necessarily provides any advantage (the tapered ends do, but the wheel placement itself I can't comment on), but it certainly didn't seem to have any negative effects.
Unread 22-12-2011, 02:51
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Beautiful first model. Keep up the good work.
If you want a real challenge, then add chain runs (depending on the program this can either be a nightmare or a few simple clicks). Adding the chain runs will let you know how your wheels and sprockets are going to be lined up.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 23-12-2011, 23:21
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
I'd like to use a one or two piece bumper on it, is there a specific way anybody would recommend mounting that?
Also I CADed a belly pan for the drivetrain. It is .05" aluminum with no lightening holes. Will that be strong enough to hold the electronics without flexing or should I use 1/16" or 1/8" maybe with lightening holes?
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 23-12-2011, 23:36
akoscielski3's Avatar
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
This is how i was gonna mount our bumpers. They aren't two piece bumpers but could easily become a two piece bumper. I have a slot that the bumper would be mounted to, it is slotted so you can easily adjust them to the proper hieght, and then tighten it so it is always be that hieght. They are gonna have a quick release, most likely a pin (like on a trailer that would go on the tongue), that goes through the top hole. the bumper brace is detatched and stays on the bumper, not onto the robot.
http://s1220.photobucket.com/albums/...umperBrace.png
2013-Present
Team 772 Sabre Bytes
2010-2013
Unread 24-12-2011, 05:40
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
I would be scared to use .05". Talk to whoever is going to make it for you if they have a lot experience with sheet metal. .125" is nice and strong if you secure it well, but it can easily bend and flex on its own. I can't imagine how weak .05" would be attached, let alone just by itself. I think ours is about 4.3lbs, but it's full of holes. Without holes, Inventor quotes about 10.5lbs.
Unread 24-12-2011, 10:51
.125" as a bellypan works perfectly well to make a rigid chassis.
Unread 24-12-2011, 20:24
Gray Adams's Avatar
Maybe I wasn't clear, but that's what we're using and it definitely is strong enough for our purposes.
