Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 24-12-2011, 05:25
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: pic: Other Swerve Drive I designed while being bored
Originally Posted by Garrett.d.w View Post
What are the advantages to 6 wheel swerve?
How else could you justify that much chain
Unread 24-12-2011, 07:43
Ninja_Bait's Avatar
AKA: Jake Potter
FRC #0694 (StuyPulse)
Who said you need justification for chain?
Nice design, though. My only qualm is that it looks a little heavy; you probably don't need that much aluminum for it to work.
Unread 24-12-2011, 14:42
MattC9's Avatar
MattC9 MattC9 is offline
It looks like every piece of AL is needed, keep in mind that you have 6 modules and you need support for each and every one of them. Here you need a frame, 6 module mounts, 6 modules, transmission mounting, and sprocket and chain hardware. Swerves are heavy by nature, so in comparison to a regular swerve this one will be about 50% more heavy than a 4wheel swerve.
p.s. to the OP, great job I like how this one can shift! I have also seen the 4wheel version of this baby and it look great! keep up the good work.
Unread 24-12-2011, 14:50
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
How heavy is this design?
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 24-12-2011, 17:18
Garret's Avatar
Garret Garret is offline
AKA: Garret Smalley
Thanks for the compliments.
With Battery and electronics this model weighs 70.5 lbs. This picture makes it look as if it has a lot more frame members than it really does. The frame itself weighs 7 lbs and is made of welded 1x1x1/16" Aluminum tube. All of the other parts including the modules are bolt on.
We already had these modules machined (they are the same as our 4 wheel swerve) which is why I used them in this model.
7 Years of FRC
Unread 24-12-2011, 17:52
MattC9's Avatar
1/16th? to hold up that whole thing? I know of weight reasons why you would use 1/16th but isn't this system taking allot of stress? I wouldn't even use 1/16th on a simple 6wd... just my opinion.
